Stock audio streaming
stefanitza
- Numar Inmatriculare: B 08 LFK
Am gasit in ultimul manual de la C4 ca mai nou ar suporta si A2DP/AVRCP. In cazul asta nu ar mai fi nevoie de USB Box daca ai BT stock si telefon cat de cat nou. Teoretic, ar trebui sa mearga cu un update de software, right?
BLUETOOTH AUDIO STREAMING
Wireless transmission of the telephone's music files via the audio equipment. The telephone must be able to manage the appropriate bluetooth profi les (Profiles A2DP/AVRCP).
1. Initiate the pairing between the telephone and the vehicle. This pairing can be initiated from the vehicle's telephone function menu or via the telephone's keypad. See steps 1 to 10 on the previous pages. During the pairing phase, the vehicle must be stationary with the key in the ignition.
2. Select the telephone to be connected from the telephone function menu. The audio system connects to a newly paired telephone automatically.
3. Activate the streaming source by pressing the SOURCE button * . The tracks to be played can be controlled as usual via the buttons on the Radio control panel and the steering wheel controls ** . The contextual information can be displayed on the screen.
* In certain cases, playing of the Audio fi les must be initiated from the keypad.
** If the telephone supports the function.
C4 Coupe 1.6i THP VTR Pack, Black
- vladut_v
Re: Stock audio streaming
Da, daca exista profil A2DP, orice telefon relativ nou stie sa faca streamming audio catre sistemul audio al masinii, prin Bluetooth. Este o minune, calitatea audio transmisa prin BT este foarte buna, este stereo si fara nici o interferenta. Calitatea este mult mai buna decat in cazul folosirii unui FM Transmmiter.
Eu am instalatia BT modelul de pe masina 2006, un Siemens VDO (cred), destul de invechit. Uite aici specificatiile la paginile 13-15: ManualC4/radiocdc4.pdf" onclick="window.open(this.href);return false; Evident am cautat optiunea inca de acum 3 ani de cand am luat masina. Speram sa stie, la cei peste 220 de Euro, cat a costat optiunea suplimentara, dar pauza ...
Daca zici ca noul sistem BT ar stii profilurile astea, ar fi extraordinar ! Poti atasa cumva specificatiile gasite in manual, un PDF sau un scan ? Plus ca pe Hi-Fi-ul tau s0ar auzi briliant
Nu stiu la ce update ce soft te gandesti, pe masina sau pe telefon ? Daca te gandesti in cazul masinii, poate vroiai sa zici ca ar fi nevoie de o activare a vreunei functii din Lexia ?!
Ai conectat telefonul la instalatie ? Daca pornesti player-ul de pe telefon, masina nu opreste sura ei audio (radio/mp3/CD) si incepe sa cante de pe telefon ?
C4 1.6i 16V Berlina
stefanitza
Da, stiu cum merge A2DP, de asta m-am si bucurat cand am vazut. Chestia de care spun e in manualul nou de C4 (incepand cu martie 2009), o sa pun un screenshot maine dar nu e nimic interesant peste textul citat mai sus.
Update-ul la care ma gandeam e pentru masina, sigur. Nu stiu daca trebuie update la soft-ul masinii in sine sau firmware-ul de la RD4 sau poate modulul BT, habar n-am cum sunt impartite. Nu prea cred ca e ceva de activat din Lexia, m-am uitat pe lista si n-am vazut ceva relevant. Cred ca pur si simplu varianta noua de soft are si implementare de A2DP.
Iti dai seama ca m-am dus repede la masina sa vad daca merge
Din pacate, nimic, butonul "Source" nu selecta decat CD/Radio. Pairing-ul e ok, ca handsfree merge foarte bine, dar nu si ca streaming audio. Ar fi o chestie sa testeze cineva care are si USB Box instalat, poate merge in cazul ala.
P.S. Mai era o chestie diferita in manual referitor la BT: acum poti alege passkey-ul folosit la pairing in loc de 1234 implicit; apare o tastatura numerica pe ecran. Deci e clar un soft diferit fata de ce avem noi.
stefanitza
La fel cum AUX trebuie activat cu lexia, posibil ca si optiunea asta de care vorbesti tu sa fie nevoie a fi activata!
stefanitza
Clar trebuie activata din Lexia ulterior, dar la versiunea de soft pe care o am nu cred ca am ce activa in primul rand.
- vladut_v
"Available during the year"
Posibil ca pe moment sa nu existe inca suportul software, sa se afle in faza de dezvoltare. In cazul asta ar fi cum zici tu, adica dupa lansarea pe piata (precedata de o mica testare), sa fie nevoie de un update de soft in centrele Citroen, pe Lexia, pentru masinile cu instalatia hardware de pana in momentul cand de va lansa.
Am bagat deja in manual treaba asta, pentru ca e ceva interesant si deja stiu ce vor face si cum va suna. Se practica !
Acum va mai dura ceva pana sa inteleaga si service-urile ce le vei cere
C4 1.6i 16V Berlina
stefanitza
Am pus si pe c4owners.org, poate stiu ei mai precis care-i treaba, cand o sa apara functionalitatea etc. Sper ca nu au schimbat modulul de BT si e vorba doar de soft! Imediat ce am noutati, pun aici. Ar fi prea tare sa avem chestia asta
Cu ce te ajuta sincer?
Iti termina bateria telefonului in cateva ore.
stefanitza
Pai nu mai trebuie sa pun USB Box in torpedou, chestie care nu prea ma atragea. Chestia cu bateria telefonului nu ma deranjeaza mai mult decat sa car CD-uri cu MP3-uri dupa mine. Singura chestie pe care as prefera-o mai mult decat A2DP ar fi mufa USB/Jack de pe consola centrala dar nu am si nu stiu daca o sa pot pune.
USB Boxul ala vine perfect in torpedou, nu deranjeaza deloc.
Ii atasezi un stick USB de 4 gb si e perfect, si uiti ca il ai acolo, nu umbli la el decat cand vrei sa pui alte mp3-uri pe stick.
Mie bateria unui Motorola Z8 in mod 'BT playback' mi-a tinut 4 ore pe un sistem de boxe JBL pentru iPod deci...
stefanitza
Da, stiu, mai stau pe net cu laptop folosind telefonul ca modem prin BT si stiu cum se duce bateria. De asta si ziceam ca prefer solutia factory care inlocuieste priza de 12V de langa bricheta, ma astept sa coste mai putin decat manopera oricum. USB Box e cam scump pentru mine, doar ca sa nu mai trebuiasca sa car CD-uri... Insa un update la software suna bine tare.
Te cred ca preferi ceva doar prin soft dar solutia asta dezavantajeaza folosirea telefonului.
Poti sa iti iei un telefon dedicat pentru muzica
PS: Vezi ca si USB Boxul tot o solutie factory e.
Ai si avantajul ca ai intrare speciala de iPod, USB sau Jack Audio normal.
Detaliaza putin faza cu solutia schimbarii prizei de pe fasca centrala...la cele ante-facelift nu e asa.
stefanitza
Modelele noi pot avea intrare AUX in loc de priza de 12V. Din pacate, nu stiu daca se poate pune retrofit. In orice caz, ar trebui sa fie mult mai ieftin decat un USB Box, n-au cum sa ceara 100 de euro pe o mufa USB, da-i incolo
stefanitza
Am sapat putin pe net si vad ca se poate face retrofit, Big Ze de la eurova2.com a facut asta pe un C5 II. Nu pot pune pozele pentru ca trebuie sa te inregistrezi pe forum la eurovan2.com ca sa le vezi; pun totusi rezultatul ca sa vedeti despre ce e vorba, nu cred sa se supere cineva atata timp cat nu se vede si cum s-a facut
E vorba de mufa aia din stanga, simetrica fata de bricheta.
http://www.eurovan2.com/forum/wip-com-r ... ocket.html" onclick="window.open(this.href);return false;
Si e exact cum credeam, e mult mai ieftin. Mufa costa ~10 euro la Citroen (cod 6574.JV), cablul USB vreo 45 euro (cod 6574.LA) dar cica ar mai fi unul care e bun la ~15 euro (cod 6574.JH). In fine, toate astea costa mult mai putin decat USB Box.
