discuri frana spate pentru Citroen C4 2004-2009
Produsul este nou, in cutie + folie.
Specificatii produs: ADC3002
Description: Brake disc
Brake Disc Thickness (mm): 9
Brake Disc Type: Solid Disc
Centering Diameter (mm): 30
Diameter (mm): 56
Fitting Position: Rear Axle
Height (mm): 69.1
Minimum Thickness (mm): 8
Number of Holes: 4
Outer Diameter (mm): 249
Pitch Circle: 108
Supplementary Article Info: With ABS sensor ring and bearing
Pret: 350 RON - ambele discuri
Contact: dragosdtz@yahoo.com
0753.300.267
