Re: Diagnoza computerizata - Citroen
Sar`na!
Pentru ca multi si-au pus intrebarea (chiar si eu, dar nu eram 100% sigur de raspuns) daca autoadaptivii se reseteaza la deconectarea bateriei, ei bine, NU. Nu se reseteaza, deoarece datele sunt stocate intr-o zona de memorie permanenta a calculatorului de injectie.
Mai jos este un extras dintr-un document de training Citroen:
VIII - INITIALISING AUTOADAPTIVES
The aim of the auto-adaptives is to maintain a perfectly adjusted injection system throughout the vehicle's life.
These values are saved in the ECU's permanent EEPROM.
These values are therefore stored even in the following cases:
• when faults are erased,
• when the ECU is disconnected,
• when the battery is disconnected.
De asemenea, multi se intreaba si ma intreaba ce este cu update-ul de soft de injectie. Acelasi document de training zice urmatoarele:
X - DOWNLOADING
Flash EPROM technology, which is now a common feature of modern ECUs, is used to update the ECU's program from the after-sales tool using a downloading procedure.
This operation is performed to solve driving pleasure problems linked to the ECU calibration.
The operation consists of downloading the new program into the ECU's memory using a suitable after-sales tool via the diagnostic socket.
This operation must be performed to ensure the system components operate correctly (no faults).
Asadar, sper ca aduce un pic de lumina asupra acestor aspecte.
X - DOWNLOADING
rado
- Localitate: Romania
Multumesc Norishor pentru update soft si pentru promptitudinea cu care ai raspuns la fiecare solicitare "after"
Parerea mea e ca se schimba ( in bine) comportamentul masinii dupa soft update .
Cu mare placere! Drumuri bune, fara incidente!
- Florinhot
Multumiri multiple lui Norishor pt update-ul de soft administrat masinutei mele!
Intamplarea mai in detaliu apare aici:
viewtopic.php?f=19&t=7881&p=214867#p214867" onclick="window.open(this.href);return false;
Repet un singur lucru: merita pana la ultimul banut
Cu mare placere! Tu ai fost primul cu care am testat si "efectul" placebo, fiind primul caruia nu ii spun ca ii fac update pentru a vedea daca este sau nu efectul mai sus mentionat, tu stiind ca iti fac numai diagnoza (tehnic, fara vreo modificare - si deci masina trebuia sa se comporte ca inainte dupa "crezul" tau).
Faptul ca mi-ai confirmat dupa "tura" de proba ca masinuta se "misca" altfel, este o dovada in plus ca orice actualizare a softului de injectie aduce cu ea imbunatatiri.
Acum... stii vorba mea: arde-i gazu`!!!
PS: multumesc pt. feedback!
46rossi
- Numar Inmatriculare: Hd40RLA
Multumesc mult.
50 RON Diagnoza + 120 RON Update-ul de soft.
Preturile sunt in prima pagina a topicului, ca nu-s secrete
In we asta cred ca ne putem vedea, dar cel mai probabil Duminica.
Daca ai ceva in cap, da-mi pe pm si vedem. Tu ai drum special spre Bucuresti ?
- vip3r_yo05
Nor, inca o data... THE BEST. Aseara la intalnire o verificare de erori si o reinitiere de auto-adaptivi. Multu' inca o data!
Ultima oară modificat Vin Aug 16, 2013 12:20 pm de către vip3r_yo05, modificat 1 dată în total.
Cu mare placere, ca de obicei!
Maine am drum inspre Hunedoara. Daca sunt persoane interesate de diagnoza/update soft/resetare auto-adaptivi, in zona sau pe traseu, dati de stire. Traseul va fi Bucuresti - A1 - Pitesti - Ramnicu Valcea - Sibiu - Hunedoara cu o posibilitate sa ma intorc pe Brasov
De asemenea, daca va pot ajuta cu vreun transport pe traseul acesta, cu mare placere.
- alex82
- Alex Ploiesteanu'
Daca te intorci pe Brasov , da , ma poti ajuta ... stii cu ce
O port cu mine continuu. E in rucsacul cu laptopul de diagnoza
46rossi
Sambata a fost Noru la Hunedoara si mi-a facut un update si o diagnoza, multumesc mult Noru pt identificarea problemei. Norishor este un adevarat profesionist si il recomand cu incredere
Dat naiba Norishor asta, promptitudine si seriozitate ce mai rar gasesti in ziua de azi!
