Eu mi-am comandat piesele, zic piesele pt ca or sa vina toate pe bucati. O sa fie o nebunie
. Inclusiv buggy-ul o sa vina sub forma de kit, neasamblat.
In mod normal ar trebui sa le am pana vineri dar tinand cont ca maine e 1.01 si nu se lucreaza... nu stiu sigur.
Cert este ca abia astept sa ajunga sa ma apuc de treaba
Iata aici lista cu bunatati:
Manufacturer: Team C
Part Number: TR02KIT
Motor Type: No Motor Supplied
Scale: 1:10
Drive: 2WD
Surface Type: Off-Road
Assembly Type: Un-Assembled (Kit)
Vehicle: Buggy
The Turnigy TrackStar 1/10th scale 60amp car ESC is the latest addition to Hobby Kings Car ESC range.
Using a Fast Silicon Labs MCU and high quality On-Semiconductor MOSFETs the TrackStar 60A ESC sets a new standard in high quality yet affordable car ESCs. With Intelligent MCU logic the TrackStar series ESCs allow extremely precise start up control and positioning feed back from the motor. This translates in to very smooth start up and acceleration.
The Turnigy TrackStar 60A ESC also boasts a host of programing options not usually found in a 1/10th scale ESC at this price and can be programmed with ease via the Turnigy TrackStar programing card (sold separately) The Turnigy TrackStar 150A ESC also included 3 x 10AWG Motor wires and 2 x 10AWG power input wires.
The Turnigy TrackStar 60amp ESC comes with an XT-60 plug and 3.5mm Bullet plugs pre-installed so you can install it in your car with without needing to do any soldering.
Specification:
Cont. Current: 60A
Burst Current: 90A
Car Size: 1/10th
Battery: 2-3 Cell Lipo
BEC: 5V / 2A Output
Motor Type: Sensorless Brushless
Size: 51.6 x 30 x 27.4mm
Weight: 78g
Battery Plug: XT-60
On/Off Switch: Yes
Reverse: Yes
Thermal Overload Protection: Yes
Motor Terminals: 3.5mm bullet
Programming Options (Via Optional programming card)
Brake/Reverse type
Brake Amount
Voltage Cut off
Drag Brake
Reverse Power
Start Power
Throttle Dead Band
EZ-RUN Brushless Motor 9T 4300Kv
Spec.
Turns: 9
Kv: 4300rpm/v
Weight: 170g
Shaft: 3.175
The HK Mi Series servos represent the next break through in high precision servo technology. Using Magnetic Induction, rather than a potentiometer, for an unsurpassed level of accuracy and performance.
Specs:
Voltage: 4.8v / 6v
Speed: 0.13sec/60deg (4.8v) - 0.11sec/60deg (6v)
Torque: 5kg.cm (4.8v) - 6kg.cm (6v)
Size: 35.6mm x 15mm x 31.5mm
Weight: 26.12g
Motor: Low Draw Coreless
Gear Train: Full Titanium Alloy
Turnigy Accucel-6 50W 6A Balancer/Charger w/ accessories (UK Warehouse)
ZIPPY Flightmax 6000mah 2S2P 50C Hardcase Car Lipoly (UK Warehouse)
